PS5 Pro BLOD - Error 80C00140 - GDDR6 VRAM Chip at Bank 1 Stays Cold on Thermal Camera
Hi everyone,
I’m troubleshooting a PS5 Pro board that is stuck on an infinite BLOD.
1. Syscon Error Log
Error Code: ⁠80C00140⁠
Interpretation: APU Halt / No Response (Forced shutdown via power button).
2. Thermal Camera Scan
Upon powering on the board and scanning with a thermal imager, I noticed that the GDDR6 VRAM chip at Bank 1 is significantly colder than all the other VRAM chips, which warm up normally.
3. My Assessment & Questions
It seems the Bank 1 VRAM chip is either not receiving power, failed to initialize, or has broken BGA connections with the APU:
Is this more likely caused by a broken VDD (1.35V) / VPP (2.5V) power line/via local to Bank 1?
Or does a cold VRAM chip usually indicate broken CS (Chip Select) / CLK / Data BGA solder joints under VRAM Bank 1 or the APU?
Samsung K4ZAF325BC-SC20
What are the recommended next steps? Should I attempt a reflow/reball of VRAM Bank 1 first, or replace it with a new GDDR6 IC altogether?
Any insights or advice from would be greatly appreciated. Thanks!
remove bank1 ram and test all useful pads on the board see if any diode reading missing
I removed the VRAM chip at Bank 1 and measured diode mode reading
⁠DQ8_A⁠ (Pin B11): 0.000V
⁠TDI⁠ (Pin F10): 0.000V
⁠VREFC⁠ (Pin K1): 0.00V
the rest pads are fine
My diode reading on working donor board(Micron RAM):
⁠DQ8_A⁠ (Pin B11): 0.367V
⁠TDI⁠ (Pin F10): 0.552V
⁠VREFC⁠ (Pin K1):1.431V
Since B11 goes straight into CPU, I guess is cpu short
forgot to mention the reading is from edm010 board but should not make big difference to PS5 PRO board
Thanks man. If ram pads ball out of edm010 is same with vsm010. Then it is not what I can fix as apu is short. Sad and unlucky.
