PS5 Slim 040, no beep, blue light for one sec and turns off
Hey there, got a PS5 here which does no beep but a blue light for 1 sec. All Fuses are okay and i cant measure any shorts. All Voltages are present. has anybody an idea what to do next?
Uart says:
Uart Error Code 80810001. Power Sequence Error, General Power Failure (Peripheral, Gddr6, APU, Data Line Short)
What is the full UART error code line?
Are there more than one UART error codes?
Hi Calvin, no, only this what i copied in here.
The ampere during start sequenz going up tu 2,5 A after a sec and than 0,20 A
UART error codes have a whole string like:
00 80000009 16A0FBB8 12000005 10000100 217B 001E 2F3C 1D7C :xx
High amps could indicate a bad WiFi chip. And 2.5A should be good visible through a thermal cam.
i dont see heat at the wifi module, but ssd controller glows as hell at the moment 2,5A are reached. Uart line as screen in attachment(last time done last month)
sxsxsxsxsx
Are the voltages around the ssd pmic for some seconds present after start button press?
what is the pmic? the SSD Controller?
pmic = power managment integrated circuit
ssd pmic = DA9081/RT5127
The are voltage measurable in the Moment i press the Button. For 1,5 sec maybe.
All of a sudden I get a beep now but no more Blue light.
Amps going to 0,15 A
Can measure voltage for about Three sec.
Are all the eight output voltages present in the seconds after the button press?
Will try again tomorrow but for now I m quite sure all voltages where present for aprox 3 seconds
I would expect one of the rails shorted or missing if the issue is the pmic chip or the ssd controller.
About the power consumption: Could it be 0.250 A in pick and than 0.020 A in idle?
Hi Calvin, i don t understand that. (i m german sorry, that means i m stupid) What do you mean in pick?
This is a power sequence from a healthy PS5 slim.
My question is: Could it be that your readings are 0.250 amps instead of which you wrote 2.5 A ?
Ah sorry now its clear. i m not sure but i think its been 2,5 .
Now its definitely 0,015 A and than dead.
