PS5 Slim EDM-040 - Freezes after boot and shuts down abruptly. Looking for diagnostic advice
Hi everyone,
I’m having a very unusual issue with a PS5 Slim (EDM-040), and I’ve reached a point where I’m completely stuck with the diagnosis.
When I power on the console, it boots normally, loads the operating system without any issues, and everything appears to work as expected. However, after running for a while, the console suddenly freezes and then shuts off abruptly.
One interesting behavior is what happens afterward: if I try to turn it back on, pressing the power button produces the normal beep, but the console does not power on. Pressing the button a second time starts the console normally again, and the exact same sequence repeats in a loop.
Based on many posts I’ve read on this forum, I’ve already performed several tests:
  • Measured the resistance of the inductors.
  • Checked for possible shorts.
  • Verified that all the important voltage rails are present.
  • Inspected the board with a thermal camera looking for any component heating up abnormally.
Unfortunately, I don’t have much experience repairing PS5 consoles, so I’m having a hard time reaching a solid conclusion.
I did notice an interesting pattern: after multiple power-on attempts, the console tends to stay on slightly longer than during the previous attempt.
I should also mention that all of these tests were performed without the heatsink installed on the RAM side of the motherboard.
I also attempted twice to boot into Safe Mode and reinstall the system software. Surprisingly, both attempts were successful. These were performed at different times, not consecutively.
In both Safe Mode attempts I noticed another pattern: the console stayed powered on for a much longer time than usual. The second attempt lasted significantly longer than the first, although I suspect that’s because during the second attempt I installed the heatsink and added a couple of cooling fans to reduce the temperature on that side of the board.
During that second attempt, I was able to:
  • Complete the initial console setup.
  • Sign in and create a PlayStation account.
  • Start downloading Astro Bot from the PlayStation Store.
The console finally shut down abruptly when the download reached about 20%.
After ruling out a software issue, I checked the UART error log. I consistently get the same error codes every time:
[Slot #]	[Date Time]		[Error Code]	[Priority]		[Error Message]
00	19/07/26 2:05:05	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 000048E2 120000F6 10010000 2186 0036 FFFF 1BC6:6A)
Click for TSB Information
01	19/07/26 2:04:53	B0088108	Low		Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 000048D6 12000005 10010000 217B 0036 2EFB 1BC7:26)
02	19/07/26 2:03:17	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 00004876 120000F6 10010000 2186 0036 FFFF 1C00:48)
03	19/07/26 2:03:04	B0088108	Low		Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 00004869 12000005 10010000 217B 0036 2D59 1C00:E7)
04	19/07/26 1:57:58	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 00004737 120000F6 10010000 2186 0036 FFFF 1C00:44)
05	19/07/26 1:57:46	B0088108	Low		Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 0000472B 12000005 10010000 217B 0036 2D16 1C00:E4)
06	19/07/26 1:55:18	80830019	Low		Known Unknown 80830019 - Report Findings
|-(OK 00000000 80830019 00004697 81BF0005 10010000 21A9 0036 2BA8 1C19:1A)
07	19/07/26 1:47:58	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 000044DF 120000F6 10010000 2186 0036 FFFF 1C46:6B)
08	19/07/26 1:47:54	80830019	Low		Known Unknown 80830019 - Report Findings
|-(OK 00000000 80830019 000044DB 12000005 10010000 217B 0036 2C3B 1C45:FB)
09	19/07/26 1:43:06	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 000043BB 120000F6 10010000 2186 0036 FFFF 1D58:68)
0A	19/07/26 1:42:54	B0088108	Low		Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 000043AF 12000005 10010000 217B 0036 2D57 1D71:01)
0B	19/07/26 1:38:31	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 000042A8 120000F6 10010000 2186 0036 FFFF 1E60:56)
0C	19/07/26 1:38:19	B0088108	Low		Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 0000429C 12000005 10010000 219F 0036 2EFB 1E80:19)
0D	19/07/26 1:31:51	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 00004118 150000F6 10010000 2186 0036 FFFF 2186:3D)
0E	19/07/26 1:31:39	B0088108	Low		Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 0000410C 15000005 10010000 217B 0036 392C 2180:DB)
0F	19/07/26 1:29:54	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 000040A3 110000F6 10010000 2186 0036 FFFF 2178:44)
10	19/07/26 1:29:41	B0088108	Low		Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 00004096 11000005 10010000 217B 0036 38C1 2179:D8)
11	19/07/26 1:11:13	80830019	Low		Known Unknown 80830019 - Report Findings
|-(OK 00000000 80830019 00003C42 81000005 10000100 21A9 0036 3535 1E5E:E9)
12	19/07/26 1:08:21	80830019	Low		Known Unknown 80830019 - Report Findings
|-(OK 00000000 80830019 00003B96 81000005 10000100 21A9 0036 3380 1D7D:EF)
13	19/07/26 1:05:32	80830019	Low		Known Unknown 80830019 - Report Findings
|-(OK 00000000 80830019 00003AED 81000005 10000100 21A9 0036 3104 1C80:EE)
14	19/07/26 1:00:45	80830019	Low		Known Unknown 80830019 - Report Findings
|-(OK 00000000 80830019 000039CE 81000005 10000100 217B 0036 2E07 1B40:F5)
15	19/07/26 0:55:23	808B00FF	Low		Known Unknown 808B00FF (Power) - Report Findings
|-(OK 00000000 808B00FF 0000388C 150000F6 10010000 2186 0036 FFFF 1A1C:6A)
16	19/07/26 0:55:11	B0088108	Low		Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 00003880 15000005 10010000 217B 0036 2808 19F8:E4)
17	25/08/62 3:22:22	FFFFFFFF	Low		No Errors
|-(OK 00000000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFF FFFF FFFF:5A)
End of errors.
Low: Nothing to concern about first.
Medium: Everything appears fine.
High: Console may boot but freeze or other issues.
Severe: Prevents console from booting.
Ignore Priority Status For Now. They are being updated!
[*] End Operation: Read Error Codes
At this point, my current theory is that one of the RAM chips or possibly the storage subsystem may have developed a micro-crack (for example, a cracked BGA solder joint), and that a reflow or, preferably, a proper reball might solve the issue.
However, this is only my own assumption, and since I have very little experience repairing consoles, I’m not confident in that conclusion.
I’d really appreciate hearing your opinions. Does this behavior point toward a RAM/BGA issue, or is there something else I should investigate before considering reballing?
Thanks in advance for any advice.
The UART errors:
808B00FF = SSD controller watch dog timer error. (case: XDPE faulty. After replacement PS5 working again)
B0088108 = XDPE bus error (case: defect XDPE chip. After replacement PS5 working again.)
The case must not apply to yours but it could be.
Thanks, that’s very helpful.
Before replacing the XDPE, I’d like to rule out anything external to the IC. Have you found a reliable way to confirm the XDPE itself is at fault rather than an issue with one of the surrounding components, power rails, or the bus?
Also, when diagnosing this kind of fault, do you normally power the board without the APU-side heatsink installed for quick measurements, or do you always keep both heatsinks fitted? I’m trying to determine the safest way to probe the board while avoiding thermal-related variables.
Thanks!
Without the heatsink on the APU, the shutdown temperatur is normally reached within seconds after start button press. For me there is no point to test without heatsink clamped to the APU.
Thanks, that makes sense.
Based on the symptoms and the UART errors, would you go ahead and replace the XDPE at this point, or is there anything else you would check first to rule out another fault before replacing the IC?
Thanks again.
You can check the readings around the XDPE chip. But the chip passed the pre boot check from the southbridge, so I don’t think you will get something obvious.
hello, did u fix this?
