PS5 Slim ( EDM-041) - No Power
Hello there,
Before: I’m pretty inexpierenced.
Begin of the repair is, that I got it with no HDMI signal… at this point it turned on without any problems. but because the display recognized that something has been plugged in but after some seconds showed “No signal” I was unsure if the problem is caused by the HDMI-Port or the Chip. I didn’t want to dissassemble the entire console - especially to the liquid metal - so I ordered an HDMI-Port Tester to check if the Port is fine.
The console was at this point not fully taken apart (took out the Motherboard with PSU , and only took away the cover which includes the “NVME Cage”.
Even in this state it worked normally.
Well it took 3 Weeks that I got the HDMI-Port Tester. In this time the PS5 was in this state as mentioned before dissassembled in a box.
After the waiting time I connected the PSU and HDMI-Cable to check if the problem solved magically itself, but now it won’t power on at all.
welp I checked now with a thermal camera: nothing at all.
The PSU is fine, showing the 12V and also directly on the Motherboard I get those 12V.
Now I don’t know anything at all - never done such a check if it show to life at all, so yea I’m looking for a Dummyguide what exactly I can try out step by step…
It is a common issue that the plastic inlet of the HDMI port come loose and with it the pins to the board.
I would check if the pins are still propper soldered to the pads.
The HDMI port tester is a breakout board?
After plugging in the power cable, the PS5 needs 5-10 sec to be responsive to the power button press. If there is an issue sometimes takes up to 30 sec. And only every second button press triggers a system start.
Hi, sorry for the late response, was now long time ill and finally back.
The PS5 doesn’t power on at all. not after 5-10sec, not after 30 seconds - it doesn’t power on at all.
What I now found out it that the 5V and 3.3V Rails are not available at all.
Anywhere where I check I just can find 12V.
Currently I couldn’t find any EDM-041 or EDM-040 guides, cause the layout is completely diffrent from other guides I’m unsure where the IC sits, which seems to be responsible to generate the 5V rail
F7001 and F7002 are where your 5v Standby output to the board. F7003 area is where stepdown ic generates 3.3v standby. Check you EDM-041 standby voltage mapping.
h ttps://imgur.com/a/rjrDcTj
Thanks for the answer.
I checked and here are my result:
Yellow = 12V
Green = 2,7V
Blue = 1,7V
Red = 5V
Everything else: 0V.
Nothing at all at F70003.
If I inject 1V the - I assume stepdown IC? - goes “hot” with 40°.
h ttps://imgur.com/a/2QNihZ0
Sorry for the links, as I’m new I can’t post links or embed pictures.
sorry forgot to mention: checked also the points of your screenshots: Nothing at all. everywhere 0V
check your fuses in the picture if they have continuity. you should have 5v both side of the fuse where I red circled them.
Nah no 5v there at al.
FUSE good? 5v on 1R0 Big coil from the cpu side I label 5v_stby?
Hi,
Both Fuse have OL, but no 5V.
The 1R0 Coil you mentioned shows also no 5V.
@jkyoho One thing I tested now, to check further:
I unsoldered the Fuses F3501, F7001 and F7002.
when I measure for OL I only manage to get it with Fuse F3501. F7001 and F7002 now no longer show me an OL.
If I measure the soldering points on the mainboard, I still get the OL.
Welp as F3501 showed me Voltage, but F7001 and F7002, means that both these fuses have a Problem?
fuses should have beep in continuity mode or show 0v in diode mode.
what mode you measured and got OL?
I used diode mode, no beeps / 0V .
With the F3501 I get a beep.
@jkyoho
An example picture (Yeah I know in this photo I’m not hitting the measure points, was hard to even get a picture like that) . With the F3501 I get a beep, but noth with F7001&F7002.
it’s a fuse, you dont have tk take it off the board to mrasure. If fuse works it beeps in diode/continuity mode, if it’s ol or no beeps, it blow and needs to replace. Find out why fuses blow is more important in troubleshoot
i found this cap on short.
but i need value to replace. can any one helpme please
those two caps are 2x 47uF
Hi. I’ve been following this post. I have the same problem with an EDM-40 board. Did changing the two caps resolve the issue?
what sizes are these capacitors? and where can I get them to buy?
I also has same issue 5v missing on 1R0 coil
I have two board edm-040 and 0-41 pls help
If u know about which ic is responsible to creat 5v let me know
