Hi everyone, sorry for long post. Can´t post images or links.
Looking for help and opinions, been having trouble in fixing a PS5 that boots and shuts off for more than a month, got it with BLOD, next day, tested it and booted fine, then BLOD again an so on, after some research got is UART errors, 80810001 along C00C0002, alternating to C0020303 and C00C0303 after booting fine and shutting off, cycle repeating. Sometimes it BLODs on cold boot, boots after some tries, most of the time boots from cold boot, shuts off in like 20min, one time played Astro Bot for 5-6h straigth with no issues, next day, same isue.
So far I´ve done:
-Checked the die for cracks,marks, oxydation, none found. Redistributed LM and checked for LM
around apu or components, all fine.
-Checked for shorts on board, and components referenced on errors, none found.
-Fuse 7001 replaced because it had 5v on one side and 4.7v on other side, thinking this was the
fix, replaced thermal putty with Upsiren UT8, still same issue.
-Took diode, standby and power on readings on XDPE and compared to ones submited by
another user on this forum, seemed fine.
-Replaced XDPE twice, diode readings a bit more close to reference, still same
issue.
-Removed all Apu coils from both sides of board(not sure if needed, but did it anyway) to safely
inject max 1v/2A on VRM area in search for shorts or heating components using rosin and ipa,
none found.
-Removed BIOS IC to dump and verify its contents, all fine, erased, reflashed, and reinstalled IC.
-Suspecting BGA issue, gave a few taps with my fingers on back of SB and Apu while running a
game, no issues on screen or system.
The systems behaves the same, boots from coldboot,but BLODs on coldboot less likely, and shuts off when its working, starts to BLOD with same error codes, then it just decides to boot fine again.
Stuck on what or where to check next, lacking a thermal camera, any recommendations?
00 30/10/2026 04:46:44 p. m. 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 000C2F90 FFFF0023 10000100 2141 0036 FFFF 2040:4E)
01 30/10/2026 04:46:44 p. m. C00C0303 Low Known Unknown C00C0303 (General Power Failure) - Report Findings - Possbile APU / VRM related
|-(OK 00000000 C00C0303 000C2F90 FFFF0023 10000100 2141 0036 FFFF 2040:68)
02 30/10/2026 04:46:44 p. m. C00C0303 Low Known Unknown C00C0303 (General Power Failure) - Report Findings - Possbile APU / VRM related
