PS5 Slim EDM-044 – Need specs for corroded capacitor near J20H104 Wi-Fi module
Hi everyone,
I’m troubleshooting a short circuit around the Wi-Fi/Bluetooth section on a PS5 Slim (Motherboard model: EDM-044).
One beep no light.
Uart Error Code: 80C00136
Cause: WI-FI or BT Problem or Power Failure - (Check WI-FI/Bluethtooh Module code thrown when module removed) - Powers off after 2 seconds
Diagnostic details:
Symptom: Short to ground on the Wi-Fi power rail.
Progress: Removed the J20H104 module, but the short remained on the board.
Cause found: Located a corroded MLCC with green oxidation near the Wi-Fi module area. I will try remove it see if clear the short.
Does anyone with an EDM-044 donor board or boardview know the exact specifications for this corrosion capacitor?
Capacitance: ?
Voltage rating: ? (Is it on the 3.3V or 1.8V line?)
Package size: ?
Thanks
10uF_6,3v_0402 (3.3v line)
