Im after some advice regarding an issue I caused with my ps5. Whilst putting it back together after applying a vynl wrap I dropped the front panel of the co sole causing the ribbon cable to the power and usb c to rip out. Whilst trying to put it back i have turned iton and it was fine but i couldnt get the ribbon cable seated properly so i kept tryinh and then it just stopped turning on. I bought a new power board and ribbon cable but it still wouldnt turn on. I went to board level with my multi meter and checked the components around the ribbon cable socket and found a single fuse at F7002 that blown and had no continuity. I also checked the power supply and it was fune. I have ordered a replacement fuse for F7002 but I couldnt find anything else obvious.
From what I have described would a blown fuse be the only issue or would it take more than that to blow a fuse?
