PS5 ssd controller issue
Hello,
We have PS5 console which does not turn on (electronics student is fixing it). The SSD controller chip gets quite warm once power is plugged. We have found older schematics for it. This particular PS5 is CHF-20XX version with EDM-40 motherboard version. I just need some instructions which could clarify me is the actual SSD controller chip done or is it something else.
What is tested so far:
  1. drawn power is around 175mA and then drops to 10 - 9 mA.
  2. 12V does come from PSU to motherboard.
  3. SSD controller fuse is tested to be ok
If there is someone who is kind enough to point us some direction i very much appreciate it.
Regards Teacher Kyltsi from Finland
For slim model, initial current draw for boot sequence is normally around 2xxmA for 2~3 sec, compared to fat(EDM010/020//03X) Model 320mA.
What exact temp does that warm stands for? 40C(normal or 70C(hot)?
check uart code?
Hello,
Ok the power drawn is around there 2XX mA once plugged in and then it drops to 9-10 mA.
We do not have exact temp for you, but when i touch the chip with finger tip i can’t keep my finger on it for a long time (5-10 sec). My general guess for that temp is around 40-50C perhaps.
I am sorry that i dont have more accurate answers.
How do we check the uart code?
Here is a link where I posted a way to read out UART codes with a CH341A programmer:
https://gbatemp.net/threads/ps5-uart-setup-ch341a.647692/
Alternative for the PS5-Wee-Tools is a web interface:
Thank you for your reply. We need to wait for the USB-TTL adapter to arrive. Then we can test this out and see does this give us more information.
Regards Kyltsi
Hello,
We received the USB-TTL device and used it to read UART codes using “Console Service Tool” software. It gave us UART codes in STANDBY-MODE. There were many errors reagarding APU. One error recommended to check fuses F3501 and F7501. We checked those with beeper and those were ok. Also checked fuses F7001 and F7002.
We copied error codes to safe place and cleared existing error codes. Then runned the process againg but now it did not gave any errors in STANDBY-MODE. We pressed the power button no powering on like it was before and also no more UART codes received when pressing “Run” on the software. Did we do something wrong?
What would be the next steps what we should do? Or is there anything to do anymore? What i have read that if APU is gone then the whole board is only worthy for donoring components. Is it so?
Regards Kyltsi
POST the actual UART reading
That usually means the error codes you haveread were old code and you are having SB or most prior standby voltage(DA9081) issue which leads to SB unable to work/ generate new code
Hello,
Here are the UART codes from STANDBY mode as is (raw text).
[*] Operation: Run Read Error Codes
[Slot #] [Date Time] [Error Code] [Priority] [Error Message]
Failed to read data
01 7.5.2026 13.36.13 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 000000E9 120000E5 10080000 217B 0016 336E 0000:DD)
Click for TSB Information
02 7.5.2026 13.36.13 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 000000E9 120000E5 10080000 217B 0016 3370 0000:C9)
03 7.5.2026 13.36.13 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 000000E9 12000005 10080000 217B 0016 3370 0000:B4)
04 7.5.2026 13.36.13 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 000000E9 12000005 10080000 217B 0016 3370 0000:AA)
05 10.5.2040 7.20.35 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 1A59B45F 150000E5 10010000 217B 001E 20FC 167F:49)
06 10.5.2040 7.20.35 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 1A59B45F 150000E5 10010000 217B 001E 20FB 167F:48)
07 10.5.2040 7.20.35 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 1A59B45F 15000005 10010000 217B 001E 20FB 167F:29)
08 2.7.2038 1.20.15 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16DB86EB 81BF00E5 10010000 217B 001E 1B83 1201:58)
09 2.7.2038 1.20.15 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16DB86EB 81BF0005 10010000 21A9 001E 1B83 1201:3A)
0A 1.7.2038 0.13.31 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16DA25C7 FF400004 10000000 2179 0006 FFFF 197C:62)
0B 28.6.2038 23.39.16 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16D77AC0 140100E5 10020000 217B 0016 2451 1A80:0E)
0C 28.6.2038 23.39.16 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16D77AC0 140100E5 10020000 217B 0016 2453 1A80:10)
0D 28.6.2038 23.39.16 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16D77AC0 14010005 10020000 2179 0016 2453 1A80:E8)
0E 26.6.2038 8.33.15 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16D40367 120000E5 10010000 217B 001E 2942 1A40:FC)
0F 26.6.2038 8.33.15 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16D40367 12000005 10010000 217B 001E 2944 1A40:E9)
10 26.6.2038 8.33.15 B0088108 Low Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 16D40367 12000005 10010000 217B 001E 2944 1A40:F9)
11 26.6.2038 8.33.15 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16D40367 12000005 10010000 217B 001E 2944 1A40:DF)
12 26.6.2038 5.31.19 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16D3D8C3 150000E5 10010000 217B 001E 3106 1E14:1E)
13 26.6.2038 5.31.19 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16D3D8C3 15000005 10010000 217B 001E 310B 1E14:15)
14 26.6.2038 5.31.19 B0088108 Low Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 16D3D8C3 15000005 10010000 217B 001E 310B 1E14:25)
15 26.6.2038 5.31.19 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16D3D8C3 15000005 10010000 217B 001E 310B 1E14:0B)
16 26.6.2038 5.27.20 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16D3D7D4 150100E5 10000100 217B 0016 2C28 1E40:25)
17 26.6.2038 5.27.20 C0020303 Low APU Not Responding - Trying Init or Reboot - 3 - (User Submitted: System wont start Blue Light Flashes), Check Fuses F3501, F7501
|-(OK 00000000 C0020303 16D3D7D4 150100E5 10000100 217B 0016 2C25 1E40:22)
18 26.6.2038 5.27.19 B0088108 Low Known Unknown B0088108 (Chip or Data) - Report Findings
|-(OK 00000000 B0088108 16D3D7D3 15010005 10000100 2179 0016 2C25 1E40:13)
19 26.6.2038 5.27.19 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16D3D7D3 15010005 10000100 2179 0016 2C25 1E40:F9)
1A 25.6.2038 2.32.27 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16D25D57 FF400004 10000000 2179 0006 FFFF 1B00:46)
1B 20.6.2038 6.40.41 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16CC0005 FF400004 10000000 2179 0006 FFFF 1C40:3B)
1C 22.5.2038 6.35.33 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 16A5C351 FF400004 10000000 2179 0006 FFFF 1CC0:51)
1D 13.6.2162 20.00.35 FFFFFFFF Low No Errors
|-(OK 00000000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFF FFFF FFFF:5A)
End of errors.
Low: Nothing to concern about first.
Medium: Everything appears fine.
High: Console may boot but freeze or other issues.
Severe: Prevents console from booting.
Ignore Priority Status For Now. They are being updated!
[*] End Operation: Read Error Codes
From these we came to conclusion that the APU might be the reason since the fuses noted on the error codes were fine.
Any other thoughts about these?
After these error codes we couldn’t get more of the same errors to pop or any other error codes.
Regards Kyltsi
I would clear the error codes and see which codes appear again.
3x C0020303 and 80000009 in this sequence show up, if the PS5 get unplugged or lose power while running.
Hello,
We cleared the codes and read the codes again. It returned no error codes. How is that possible? We double checked that the RX and TX pins were correctly soldered to the motherboard and the gnd was also soldered to correct position.
And we are still on situation that console has standby power and after power button press no power.
Regards Kyltsi
TX and RX do they have 3.3V?
Disconnect the uart from the PC, connect the PS5 to the power, make several attempts to turn it on from the on button and then reconnect the uart to read errors
