Hi everyone, on my EDM-20 board, I measured the impedance at the RAM switching regulator, and it fluctuates between 160 and 200 ohms. From what I understand, it should be around 40 ohms.
Where should I continue looking for the fault?
The UART output shows the following error:
25.04.2026 14:51:33 80810001 Severe
PowerSequence - Power Sequence Error - General Power Failure
(Peripheral, GDDR6, APU, Data Line Short)
The resistance to ground depends on the RAM manufacturer. I guess your GDDR6 RAM chips are Micron, where I would expect ~190 Ohm. Samsung chips would read resistance to ground ~40 Ohm.
Are there more UART codes?
Please provide the whole UART error string.
It is alway´s the same errorcode. After i cancel error code list i get this:
[*] Operation: Run Read Error Codes
[Slot #] [Date Time] [Error Code] [Priority] [Error Message]
00 25.04.2026 14:51:33 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 0000:D8)
Click for TSB Information
01 25.04.2026 14:51:33 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
02 25.04.2026 14:51:33 FFFFFFFF Low No Errors
|-(OK 00000000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFF FFFF FFFF:5A)
At power-on, the thermal camera shows that the SSD controller is heating up, and the GDDR chips also heat up briefly, but the NAND ICs do not heat up.
It is possible. But I would check if there are any issues with the voltage lines for the APU. Maybe one line has a short or is missing.
The voltage should appear at least for some seconds after start button press.
@Calvin Please excuse the mistake — I marked the points incorrectly.
I measured again, and I do have all the Power ON voltages as you specified. They are present for about 200 milliseconds during Power ON measured whit oszilloscope.
PS5 UART code [Slot #] [Date Time] [Error Code] [Priority] [Error Message]
00 2026/6/22 16:30:27 80802205 High Not found in list. Report Findings.
Click Here To Report
|-(OK 00000000 80802205 00001250 FFFF0005 00000100 2013 0036 2913 1D2D:02)
01 2026/6/22 16:28:54 8080222A High Not found in list. Report Findings.
|-(OK 00000000 8080222A 000011F3 FFFF0005 00000100 2013 0036 299C 1DF8:43)
02 2026/6/22 16:28:40 80802205 High Not found in list. Report Findings.
|-(OK 00000000 80802205 000011E5 FFFF0005 00000100 2013 0036 2904 1DC0:13)
03 2026/6/22 16:28:18 80802205 High Not found in list. Report Findings.
Feedback: I checked it again with an oscilloscope. The 0.5 V rail (marked in red) should actually be around 1 V, according to another user on Discord, but I was only measuring about 0.5 V.
It turned out that the TPS53219A buck converter was faulty.
