I watched a TronicsFix YouTube video about fixing DS4 controllers. I successfully replaced the joysticks with OEM replacements. Now my headphone jack does not output audio. The DualShock4 internal speaker still works. I am lost on why the headphone jack does not work. I could not find any schematics for the controller. Suggestions would be appreciated.
Well first thing I would do is make sure nothing has slipped out because if something has there’s your issue if not it could be that part is faulty
Thanks for the reply:-) I have not found anything out of place. The replaced joysticks work great! I must have broken something when I soldered in the new control sticks. I just don’t know. I wish I could find schematics for the DS4 controller. Best wishes.
Did you figure out what happened I have same problem and all I can find on Google is instructions on resetting controller , make sure settings are correct, and make sure cable is plugged in all the way
Never got the controller to work. Headphone jack fits tight, clicks. Tried tracing the circuit to no avail. A schematic of the DSC would really help, but I have not found one. I set the DSC aside, and I guess I will use it for parts.
I appreciate the reply. A little slow getting back to you, because I don’t visit forum frequently.
Never did get audio back via headset. I couldn’t find a schematic, so I set the controller aside.
Mate I discovered this on my dual shock 4 hope it helps it could be either causing your issue but likely the control ic chip
Thanks for the info. I will have to look more closely at those chips.
Best wishes, Bubba
