thanks for all the info. I’ll report back with pictures once I have it all completed the fix
Update: The switch is back to life now and working in dock mode, thanks to all that help me along the way
The switch should have been fixed a month or two ago but I reverse the red/black probe when comparing to Calvin diode diagram. As a result, I did not get the diode number and thought my p13usb was faulty and ordered more.
My apologies as the job look really crappy under the microscope, I have tinned all the pads properly but with flux/lighting it looks like the pads are not tinned at all. i have also replaced the 0201 0.1uF that got blew off (left bottom) before putting it back together.
Well done man! glad you got the switch up and running again ![]()
Sure it will look fine once you’ve given it a scrub down with some IPA
For future reference, try to avoid covering passives in the UV mask, it can lead to issues later down the line such as cracking and/or changing the thermal characteristics which in turn could change their values. Don’t think it’s a big deal in this case, but worth bearing in mind
