PS4 Pro
Model CUH-7015B
System 7.55
Issue Detail:
I have never had any issue since I bought it. Recently, it starts and runs normally for an hour or so, then it will reboot, but not totally… The white is still on, fan is running, even disk is still working. But the HDMI and USB port has no response, also controller lost connection and couldn’t connect back. Then I have to manually press power buttn to turn it off. After that, still able to normally start it and it will do the same after an hour… If I open up a game, it will go reboot less than 30 mins.
Test and Solution:
- Overheatting
I thought it might be overheating issue, then I opened it up, cleaned it(not much dust at all), made sure fan is smoothly spining and replaced Grizzly thermal paste and pads.
Still not fixed
- Place it to a more open area and plug on a different power outlet on the wall
Still not fixed
- Change a HDMI cable
Still not fixed
- Replace the original HDD with a SSD and reinstall system
Still not fixed
- Safe mode rebuild database and update system
Still not fixed
- Change a new power cord
Just ordered it, it’s on the way
- Voltage Unstable
Next Try
Summary:
I think I still cannot address what the problem is. Please let’s go through the logic with me… First, it can normally start, so it means there is no hardware problem at least within the first hour, which means chips, motherboard, ports are not burned up. Second, I updated system, then it’s not a software problem. Then, what is the cause to make it abnormal…
I called a local repair store, the technician said the southbridge chip might be broken. I don’t think so… If it’s broken, then I won’t be able to turn it on or won’t be able to see the display through HDMI at all. I know why he said so, because the HDMI and USB port are no response at the same time, but there must be a trigger to make it off right? High voltage while playing maybe???
I just remember there was a power outage in my area few days ago. That might be a trigger… but still I don’t know which part is not working.
For those guys who have experience, please help me address the problem. I really believe I can fix it by myself.
By the way, I’m surprised this forum supports Markdown, LOL. Awesome!
