How does one get permission to post a picture or is there someone who I can send a the photo to to upload?
let me help you upload your pic
FYI, check your port and see if any pin inside jamed together
Thank you very much jkyoho !!! I’ll check as you suggested.
Most likely bent pins in the charge port. I have several like this and it’s all had bent pins causing that to short
Thank you. You were right about the pin. Now it powers with Nintendo logo then nothing so going to continue to trouble shoot. It appears it will not run on battery as well .
Okay it looks like the connector to the battery is loose or shot. If I press firmly on the connector with battery system boots up just fine…
