Hello friends. I have a board where I can’t remove the short at the M92. I have desoldered the chip and the cap and tested without the chip. Unfortunately, the short remains.
Where does this cap lead and what else could it be?
I also desoldered the BQ chip and the USB port to test.
I have a short on this cap in my switch. Does anyone have a link to a product page with that specific cap? I’m having trouble sorting through all the different capacitors that I’m seeing it might be.
Thank you for the detailed answer. That’s the value I seemed to find as well. I tested the caps using continuity on my multimeter and that was the only cap that generated a tone. Are there any other tests I should be conducting to be certain about that cap being the bad one?
well, most cap goes to ground on one side, that’s what cap does in most time.
VDDIO/1.8v comes from MAX7760A/H. So A big warning for you to check around.
Very much appreciate the input from someone more knowledgeable, thank you. And yeah, while I make no claims of being an expert or even qualified, I figured that’s standard for capacitors unless they’re in series. I just wanted to point that out (probably un-necessarily) in case they were meaning that they were reading the one side shorted to ground, because… that’s expected. Sorry.
