Hey there,
Pin 5 is a voltage generated by the M92T36 to supply a few other chips. Most of those chips do have a cap as close to theis supply pins as possible. There’s a big cap right next to Pin 5, which might also be broken. And from what I can see you didn’t try removing that one.
Hey.Thank you for the answer. I ve already desoldered M92T36 pin5 cap.Desoldered cap conected to same rail for PI3USB and PI3USB itself as i already mentioned.
I couldnt find any more components conected to pin5 rail to check except caps to the botom of PI3USB.
Red on the images are desoldered components/
Red square with an arow are 4 caps wich are still shorted but they all have same 0.38 Ohm between them so im not sure if i should desolder 4 of them, would ve like to avoid it.
