Hi guys, fairly new to the scene and been having success on some repairs. Have a Switch Lite in with an obvious charging port issue, replaced that, found some shorted caps on the M9 so went ahead to replace (first time). Accidentally knocked what I thought was one cap off, reflowed, tested, 12.2v going in, 0 amps.
Took it back apart, compared it with another board and noticed I’d knocked off another cap. Been trawling the forums and found some promising pics with cap ratings, but none seem to have this one. Believe by the size, it’s going to be a 0201 but unsure on microfarad/voltage for it. Any ideas?
I can’t upload images, guess because I’m a noob so I’ll try to explain
Looking at board from the correct way up, USB port at the bottom. 0201 cap left side, 0201 resistor just below that. 0402 cap offset to the right under ‘M92’ on the chip. It’s the small 0201 cap below that, very central to the chip itself.
