Hi guys, I recently spilled a glass of water, absolutely clean water by the way, on my switch. I quickly grabbed it and smacked out as much water as I could out of the fan opening and the power/volume rocker areas since that seemed to be where most of it ended up. Then once I was done with that stuffed it in a ziploc bag with several silica gel packets for a few days. I just came back to it and the console does turn on and does charge but the screen won’t turn on. It does respond to touch however so I think the digitizer is fine. Is there anything I should look at first to diagnose the problem area? By the way hdmi does work when plugged in and I personally have the feeling i may have dislodged the screen’s ribbon cable when I was knocking it a bit but I haven’t opened it up yet so I don’t know how easy it is to dislodge it.
Any advice?
Thank you!
