I have a gamecube I just bought used online that I want to open up. The 4 “security” screws that hold the two shell halves together are spinning with resistance as if they’re unscrewing but they aren’t actually backing out of the hole. I think the people that had this gamecube used too much torque when putting the screws back in and broke the plastic threads on the console.
Despite all 4 screws showing the exact same behavior (spinning but not unscrewing) the two halves are firmly held together as if the screws are not stripped and they’re properly doing their job.
I registered here because I’ve seen the YT videos several times and I’m a big fan. This was the first place I thought of to ask for competent help on this subject.
I was thinking a drill press might be able to get a straight drill path on the screws. I tried w/ a hand drill and it wasn’t going to work, the bit wanted to go between the screw and the plastic which would have just torn up the console.
I hope someone can help, thank you.
