I have a water damaged Switch. The battery appears to be charging, and there are no shorts anywhere. I discovered if I put it into recovery mode that the screen goes from just black to having a bunch of odd horizontal lines on it, which I believe means the screen is bad, also not a surprise.
It does NOT work in docked mode either, so my guess is that’s the PI3USB chip, since it controls the HDMI etc.
So if I replace the screen and digitizer and PI3USB chip do you think it will fix it?
Again, NO SHORTS on any chips at all.
Thanks!
Jeff
