Hi everyone.
Im new to microsoldering and reparing switches.
So, I’ve bought a switch that doesn’t power on : drawing 0.47A when battery is plugged in, 0.2A without it.
I checked for shorted caps on the VSYS line (around BQ) and I found nothing suspect.
Same for M92, same for P13.
So, I have few questions :
Is that normal that when I plug in the battery the CPU gets warm (not crazy hot, just warm), it seems like the battery is draining into it.
I removed the BQ chip and… 0.000A consumption and no CPU getting hot. Should I consider the problem as solved?
An other question, what diode reading indicates a short ? I have no beep on my multimeter. Is 0.171 considered as an acceptable value ?
Is it normal that I have 0.00v voltage drop on caps when battery is plugged in (so considered as shorted?).
It seems that I have a short on the cap bellow the M92 (0.075 diode reading), on this very cap :
tronicsfixforum. com /uploads/db3735/original/2X/a/a8aeb40300f3a17bc4a8073eee9527acd176327d.jpeg
Thanks everyone ![]()
