Hello, I have been having an issue with my Switch V2 where the console will be in sleep and either shut down completely or will pop up the error code, 2107-0114, while in sleep. Looking around online, it seems like it may be an issue with the WiFi chip? Is there anything I would be able to do about it or would I have to send it in? Thank you.
Likely need to replace wifi chip.
Will I need to send it to Nintendo or would I be able to bring it to a shop? I heard somewhere that the wifi firmware doesn’t allow for other wifi chips
You will need a used Wifi chip from another board if you want to do it by your own. Not the easiest job, you you should if you can do it by yourself. If there is warranty I definitely would give it to Nintendo.
