Hi, i have a Switch with a strange fault.
The Switch was waterdamaged. I cleaned the board and replaced the lcd connector. After assembly when i plug in the battery the fan starts to run at 100 %, but when i boot into horizon the fan works normal. When i fully shutdown the system the fans runs again at 100%.
Do you know what is causing this fault?
I bought the Switch broken.
I solved my Problem.
It was the fan connector on the Mainboard.
The pins lost their Connection to the pads on the mainboard.
I know this was a while ago but do you remember which pad was bad? Have the same issue exactly but struggling to work it out.
