Switch Lite charging issue
This is a weird first for me. When i plug a charger in while the console is off, everything works normally and it charges. When I plug the charger when it is on, it does not show a charging icon. The weird part is on my meter it is accepting a charge at 0.43 amps. I do not understand
What size charger are you using and from the icon is the battery fully drained? Seems to be on trickle charge
Can’t seem to edit/ add to my post , meant to add have you checked the power management IC and the port, does it trickle with the charger plugged in in both directions?
