Switch Lite Error Code: 2153-0321
When I turn on my (unmodded) switch lite, after the Nintendo logo it shows “error code: 2153-0321….”. If I plug in a headset into the audio jack and then turn it on, the switch turns on like normal. Once the switch is on and working, if I disconnect the audio jack, I get the “error code: 2153-0321….” again.
What I’ve already tried:
  • Disconnecting the speakers, turned it on, same error
  • Disconnecting the card reader/audio jack module, turned it on, same error
  • Change in settings, mute audio when headset is disconnected, took out headset, same error
  • Examined front and back of motherboard under digital microscope to look for any trace damage, there is none.
  • There is no corrosion on any components
Does anyone have any experience with this problem and did you have to replace any chips, capacitors, resistors or diodes?
How do I use my multi meter to check for shorts?
Thank you for your help.
