Hi guys
I have a Switch Lite that had a bad damaged charging port, upon inspecting the M92 there were shorts on Pins 38,39,18,6
I removed M93 and the shorts on pins 38,39 were cleared but 18,6 remained,
I then removed both caps from each line and short is still there.
I soldered a wire to pin 18 and injected 0.9v and the board was pulling around 1.5A but nothing was warming up under the thermal camera.
Would this indicate a shorted SoC? as it is big enough to absorb any heat, any other component surley would of heated up.
