Switch lite mod screen doesn’t turn on
Hi all,
I just modded my switch lite with a picofly chip. The problem is: when i press the power button, the picofly chip starts flashing a blue light a couple of times (sometimes once, sometimes 5 times, and just now 11 times), then finishes with a green light flash, but the screen doesn’t turn on.
I started this project months ago, and just finished it, but the battery probably died during these months, so i have the switch plugged into a charger now. This doesn’t make a difference however, the switch does these light flashes when i have it plugged in or when i have it out of the charger.
Some things to note: i don’t have a multimeter (yet) so i cannot check my soldering. Also, i have never flashed the modchip with firmware, as i never got it to show up on my pc, but i just read today that this might be because of the type of cable i was using. I ordered a new cable to do this, but do you think that is the (only) problem here?
What would be the best way to go about debugging this?
same with me and still don’t know what to do
