Switch Lite no power and not charging
Hi all,
i worked on other devices and this is my first time with a Switch Lite so i hope to get some help. :slight_smile:
The Switch came with a burning hot MAX77812 and Bad looking USB port. The repair shop which looked at it also pasted thermal paste everywhere. I replaced both parts and it looks like the Switch wants to start (15v, 0,04a and 2w in a loop. With the battery connected nothing changes and the battery ist not charging.
My latest board check showed a cracked big component (inductor?) near the connector for the gamecard board. Can anybody tell me the value for this part and what it is?
Can this be the problem for my faults or can this also bei caused by a bad MAX17050? The resistor close to it should have 50 ohms but i only get 0,8 but with the MAX17050 removed it stays the same.
Thanks in advance for ideas.
Somehow i cannot add any pictures.
