When I plug in my charger I get the battery icon and then a black screen. Then I press the power button and see then nintendo logo for about 3 seconds and it reboots to the battery icon for about 2 seconds and then to black screen. It keeps looping back to the charge icon on then off, on then off. No shorts, M92T36 replaced, different batteries tested, usb port changed, and 3 different official chargers tried. Any idea’s?
hello…
It could be that the m92 ic…is damaged
given that in certain cases it does not send short…
2…after the logo and the battery icon appears, hold down the power button until the icon disappears, leave it for 20 to 30 minutes until it has obtained enough charge to turn on…
Could you try this, greetings
what current draw from the charger?
15 volt 0.46 amp. It also reboots my amp meter.
Just replaced the bq chip with same issue. Switch just loop boots to the charge icon?
