I recently changed out my switch lite shell and decided to also change the digitizer to match the shell.
Since I had to change the digitizer I also had to change the LCD screen to the new digitizer. I did not force the screen off nor bent it but used alcohol 70% and the iFixit picks to remove it from the digitizer and it came off with ease. Now I got a blotchy patch on the right side of my switch screen. It’s lighter than the rest of the switch. I’m wondering what I did wrong and if I have to buy a new digitizer+ screen combo from IFixit to replace it.
Exactly, the backlight white plastic cover is easy separate away from LCD crystal panel, they are not water-proved/sealed but only stick together with adhesive tapes
So I checked it today and there are still faint lines on the corners of it. I applied a heat gun and it did not affect it. Are there any other fixes to it or would I have to disassemble the switch? Or and I SOL and these marks are actually permanent?
How do we post pictures in this form so I can get an opinion/ idea on what the issue is?
