Switch Lite Water Damage / Help
Hey guys,
I need help with my Switch Lite.
It fell down in the bathtub. :frowning:
After it the screen was colorful and went of. Short Circuit I guess.
The switch still powers on and reacts to touch.
After a few days I opened it by myself and cleaned a bit corrosion around the LCD Connector with 99% isopropanol-alcohol.
But I saw that the connector itself has a ā€œblackā€ pin -also the flexcable does.
Is that maybe the problem?
I haven’t repaired anything by myself so far, but I am very interested in fixing and I’d like to try to do this by myself. Is it possible without professional equipment?
I attach some iphone shots (sorry - the zoom isn’t better) and am thankful for each advice.
Regards,
Looper
I don’t know, but I can’t upload any images or include links…
You’ll likely have to replace the connector, I would guess it’s backlight which has burned up, so possibly the IC too
You’d need a hot air station to remove both and put back on replacements, and you’ll need a soldering iron to wick and prep pads etc
