Hello!
I’m having an issue with a Switch Lite. The USB C port was damaged so I changed it myself. As a noob in soldering, I am not sure I have done a perfect job with all the pins. It won’t turn on. I get 4.2V for the battery connector when plugged in, but everything seems dead. How can I check that the mainboard gets power from the USB C? Is there a debug sheet for all the control pads or how are they called?
Thank you in advance!
