Hi all, so my kids damaged the USB port, I have replaced the port, as I have had the port off/on few times I have now lifted the second pad from the left (hidden pins side)
I have checked the caps around the M9 chip and around the P13 there appears to be no shorts (only continuity to ground on one side)
I checked the chokes for continuity straight and for shorts “cross ways”, I did find one of them shorted, but I believe that was caused by a soldier bridge at the port pins(the short has now gone)
So, if I run a jumper wire from the port pin that has the missing pad to the second from the left choke (seems to be RX1+) would this over come this issue?
I see that people do diode test from the back (hidden pins) but I can not see the pins at all, maybe I have a different port, seems to have a plastic edge, maybe this can be removed to see the pins? Perhaps this will be the way to fix the jumper wire to?
I would suggest u to take the connector off and make sure that the pins and vias are connected as they supposed to (create the necessary jumper wires and do the green coating) and after all is prepped solder the connector back to the mb.
Also, when I docked (with the jumper wire installed) the dock flashed green, now it appears that the dock has stopped responding, even using another switch…
You could try to replace the Pi3usb Chip on the backside, it solved my problem once. and I have seen that other people have recommended that solution as well before in other cases.
Perhaps that is a solution for the switch it’s self, however now I’m concerned that now the dock is not working. It was perfectly before. I have also tried another switch to confirm.
