Hi, i have a Switch which was probably waterdamaged i cleaned everything changed the lcd connector and usb c connector.
When i replug the battery i can turn on the switch and everything works fine but when i do a system shutdown (long press power button and chose shutdown) it wont boot HOS anymore. RCM does not work too. The switch does charge normal with 1.4 Amps but it wont boot anymore. Does anyone know what is causing this fault?
