Switch OLED had blue screen after modchip install, this was fixed, now it has black screen after Nintendo logo
I installed a modchip (from Aliexpress) in a Switch OLED. The install went fine, it wasn’t my first OLED. After getting a succesful glitch and the “No SD card” screen, I did the test with bypassing the chip to see if it boots to the OFW, but I got blue screen. With an SD card inserted and the necessary files on it, it would not boot Hekate. I checked the board for any damage, nothing stood out. Btw, I used a DAT0 adapter and the flex cable that came with the chip on the CLK, CMD and 3.3v points. This Switch has an SK Hynix eMMC. I only mention these details because I don’t know if it’s relevant to the current issue with it.
So I sent the Switch to a repair shop, and they fixed the blue screen issue by replacing the RAM chips. They also told me that they inspected the board and could not explain how or why the RAM chips broke.
After fixing the blue screen, they set up emuMMC on the console, and managed to successfully boot into CFW and OFW, but only 2 times. The third time, it would not boot into CFW nor OFW, it just went to a black screen. When they removed the chip, the console shows the Nintendo logo, then black screen.
Then they tried a couple more things: reflowing the RAM, reflowing the APU, and replacing two Max chips on the board, the Max 77620h and the Max 77812. Nothing changed, still black screen after Nintendo logo. They also checked the entire board for shorts with multimeter and thermal cam. After that they sent the console back to me.
Here’s what I tried after that, but sadly with no change: I installed another chip, this time an RP2040-Zero, using wires, and using a different DAT0 adapter. (I read a couple of posts on other sites that mention that if you have an SK Hynix eMMC it’s better to use wires when installing a chip. I don’t know if this is true or not). I measured the readings to all points, they were all within range. I also tried with a fresh Atmosphere and Hekate setup on the card. I still get black screen when trying to launch CFW, same with stock OFW. No Nintendo logo, no Atmosphere logo. Only if I bypass the chip I get the Nintendo logo then black screen.
I have a nand backup, and I have the prod keys. I also checked the eMMC partitions in Hekate and they show no errors. The battery also seems fine, and the console is charging if I connect the charger.
My question is what could have caused this problem and is there anything else that I could try with this console? Any help would be appreciated.
Revisa solamente las resistencias de arriba del procesador la de 100ohms y la de 3,3ohms alguna de las dos te la has llevado sin darte cuenta saludos
