I am trying to fix a switch board HAC-CPU-10 that only charge with a 5V charger using the nintendo official there ir no 15V in the fuse. What I checked (in diode mode):
Fuse is ok
M92T36 pin 6 cap is messuring 35
M92T36 pin 36 is messuring 0 on both sides
PI3USB caps around it are messuring 35 (removered the IC and still same values)
When connecting 5V charger (mobile charger) pin 6 has 3,3V
Any idea how to proceed?
Thanks for your help
hi jkyoho
value 35 messured in all caps around pi3 and pin 6 cap is 0.035 in diode mode
also looks like the cc1 line is shorted, I desoldered m92t36 and now 0L messured at cc1 and cc2 test points in side B of the board (same on side A)
Today I’ll change with a new M92T36 and share results
