Switch Picofly glitch timeout (===)
Hi there, till last night my switch v2 with Picofly installed was working fine, but when I woke up today It would not respond.
I restarted it, then it started glitching till timeout (===). What I’ve checked so far:
  • Solders seems good, I just retouch them in case of cold solders
  • I cleaned some thermal paste, which was overflown
  • I can boot OFW without SD
  • CFW with SD will always timeout (===)
  • CFW without SD gives me the “No Sd Card” message
Do you have any ideas?
Hello, I know it’s been a year but i’ve had the same issue lately.
This problem occurs, when the CPU-pin is shorten
Here is how i solved it:
I’ve straighten the end of the wire, soldered to the CPU-flexcable. After a successful poweron (no SD-screen), I’ve put some soldermask on the pins of the flexcable, this way you can avoid the pins to shorten.
Best wishes!
(Sorry for my bad english, I’m german)
