I had a trinket installed on my v1 by a modder in May with emunand, was exfat and everything was fine. Then from mid June was getting a lot crashes fatal error occured when running Fusee. Failed to initialise the SD card: 0x00004a18. This message stopped when I tried a different card or possibly when I deleted a folder from contents folder in atmosphere. On new card its fat32 but it still crashes randomly still crashes or freezes randomly.
Opened it up and removed the card reader part, couldn’t see any broken pins. Cleaned the contacts. One thing I noticed is that switch gets warm a little warm compared to oled. Also when placing flat on desk sometimes causes the crash. I noticed that if I tap the back case, a red light flashes which then freezes/crashes the switch. Sometimes it says failed to init SD card but still works until it freezes then somes that message.
Is there a way I can link the pic of the install?
