Switch wont charge Recently installed a battery due to battery having a no charge issue i thought nothing of it at first replace the battery boom charging again then a day later i installed a RP2040 no issues charged fine but a day later after the switch reached full charge it was stuck at 92% i thought nothing of it just believed that the jailbreak was just preventing it from being fully charged but after i removed my charging port and plugged it back in it would not charge at all so i decided to check the board to see if any shorts were made and to my surprise no shorts near the power ic or the battery ic so i decided to let it charge on a slow charger it did nothing after being left on the charger for 24hrs i checked and the charger had 5v going in and 3v at both charge and battery chips([M92T36 and BQ24193) after that i had a friend thats better than me at soldering to replace the charging ic and the usb c just based on speculation due to no shorts and that it looked old, this allowed the switch to charge again for 2 days, and again after day 2 of use no charge but this time with 15v at the charger with a 60w block the switch ended up working again for a full day after repluging the battery but again stopped charging after about 12hrs this time the 60w block is only giving 5v at the charger and 3v at both ic’s at this point im stomped and dont even know where to begin for a diag if every diode on the top of the board is not shorted i know this was a long winded story but i believe that context in this issue is very necessary
- (Key points for the people with short attenetion spans)
- replaced battery due to no charge and was dead for over 4 months charged fine for 1 day
- installed a RP2040 no issues charged fine for 1 day after it was stuck at 92% while on charger after switch was unplugged it did not charge again
- replaced charging ic based on the 5v reading coming off of the charger and the 3V reading coming from both charging and battery ic’s no shorts were found around both ic’s
- switch was able to charge after parts replacement but stopped after 2 days of use
- tested switch and found 15v at the charger let the battery sit for 2 hours plugged it in and charged again for 1 day
- after usage the switch would not charge checked the charger reads 5v and both charge and battery ic reads at 3v while being plugged into a 60w fast charger its been 2 days and the same reading is happening since before the parts change help or advice would be appreciated before i just buy another v1 and use this thing as a donor board
