Hey
I would appreciate a small question and help from your knowledge. I sent my console regular ps5 to be cleaned at the lab. After it came back, I had a software update. The update failed and it said something was wrong. I tried resetting the console and nothing helps. In any case, it says something went wrong I also tried an external update with usb and tried option 8 in safe mode. and Iām out of warranty. Do you have any idea what it could be? I would appreciate your help.![]()
if it is a disc drive model, check and reconnect the disc drive 2x-pin flat data ribbon cable if you can.
Thank you, I will check and update if this solves it.
Thanks, that was really the problem, the drive was disconnected.
