Tmr stick replacement problems
hi, after replaced the analog sticks in my 1914 controller, both of them are stuck at 4 o’clock position, after checking the jump wiring diagram i measured the resistance with a multi meter to all of those points and it seems to have continuity, however after that i have found that the rsx-tp112 line is shorted to ground, also i have knocked off the c21 and c25 caps near the left stick but apparetly this should not affect the use at all, i have soldered a piece of wire in just in case. i can’t remove the tmr stick without causing damage to it, since not having the tool or a hot air station, so am i right thining te short is either in the board (damaged) or i the stick itself? if it’s in the boad can it be repaired somehow?
Hey there, are you sure you re using the right sticks? Do you have sticks left which are not soldered in? Pls measure the Ohms between ground (anchor legs) and the “potentiometer” legs.
In my case i bought TMR Sticks for a PS5 Controller and received xbox TMR sticks by fault. The result was that my sticks stick at 9 o clock
bit late,
that board had a short to ground on one of the joysticks and i have knocked off some components. now sold for parts. since i have fixed 5 joysticks, but they are hard to sell, so i’m done with it.
