Hi
I have 4 torn pads on the USB-C traces. I only need the Switch to charge.
I am unable to attach an image showing the torn pads but it is the following pads
A2 and A3
B3 and B2
Are these pads require for charging as that is all I need to do
Many thanks
jkyoho
2
since lack of DOCK mode support, you can ignore those pads.
For Slite, only VBUS, CC1,CC2,Sub1,sub2,d+,d- are important
Hi,
Thank you for the quick response. So I can just solder on a replacement USB-C port and it should still charge?
