Hello,
I am dealing with a very odd issue with USB detection on the Switch.
Here is what it does do:
- Charges.
- Outputs to HDMI
What piqued my curiosity was the it did not get detected when charging via USB 3 port on my computer. I would expect it to make the connection sound like when my phone is connected, but it does not. The USB-C port has already been replaced, but the issue persists.
Any ideas?
Is there anything else you need it to do?
It works on another Switch, so there is something wrong. My concern is with any USB-C peripherals I may use in the future. I have yet to check that.
The issue is more likely on the computer end my hp laptop doesn’t detect my phone while my gateway laptop does it’s your computer mate they are picky
Tried virtually every port and cable I own. Last check is OTG to my phone. My OCD is driving me crazy, must make it work!
Go into device manager and install it manually that’s what I have to do
OTG did not work. Will try manual install.
Manually installed, but get:
This device cannot start. (Code 10)
The specified request is not a valid operation for the target device.
