Hello everyone,
I have a 1st run unpatched (sn#xaw1007) on stock firmware. My switch went unused for awhile and last week I got it booted up and updated controllers/dock etc and installed advance wars. However I noticed the left Joycon was almost dead and not charging. Seeing as this is old hardware I figured the Joycon batteries had given up, and got some replacements on Amazon and installed them no problem.
Next I notice the left Joycon still isn’t charging, and the right one will only charge when system is unplugged or undocked. so I research and find out the fan is on the same charging circuit but my fan works still, not sure if it’s full speed as I remember but it’s on.
I then tried the Hori control pads and the left unit is not working which means I assume the switch is not powering or communicating with the left rail, even after disconnecting/re-pairing etc.
Not wanting to lose my saves and seeing how this was going I went out to local GameStop and got an oled switch and moved my saves/games over to the new system so this one is just for science now.
I then re-initialized the console and now when I put both Joycons on the switch, plug in the oem charger and unplug it the right Joycon starts charging but the left joycon charging icon flickers from charging to battery level and just stays showing level. The only way I am able to charge the battery is to disassemble the Joycon and switch the batteries.
I am not finding much info on this issue and am wondering from someone with better understanding of the Joycon charging circuit if this is worth tackling on component level or is it just easier to put a whole new motherboard and get new Joycon (the left one acted up after the 3rd disassembly and the sync button stopped working). I wouldn’t want to put a new mobo in and still have the issue so any input you can provide is welcome, thank you!
TL:DR
-First gen unpatched switch on stock firmware fan still working not sure if it’s 100%
-left Joycon was dead, bought new batteries and still left was not charging, swapped batteries to charge.
-joycons are not charging while plugged into the power adapter, only when un-plugged
-initialized the console and now the left Joycon charging icon flickers for a second but returns to battery level and not charging.
-Need to know if it’s worth diagnosing on circuit level if there is enough known, or just buy a new mobo and joycons.
Thanks again!
