What’s the best way to remove old adhesive underneath the digitizer?
Cheers
Cheers
i used hair dryer/ blower, used 3m double sided permanent tape
I’ve used a rework station be careful not to have it too high or on a single spot too long or your replacing your touch screen
Dissolvent worked fine here, be carefull with it thou, it can damage any hardware it touch
Usually you can just peel it off. Any residue can be removed with IPA
Hey there,
Adhesive remover also works great.
If you remove the electronics you can just use a warm damp cloth or better yet remove the front panel yes the switches touch screen mount is just screwed on shove a screw driver through the adhesive remove the screws i’d advise putting them in a jar or other container then just take it to the kitchen sink and use a scourer and water to remove the adhesive simple as that don’t forget to remove the screen though I won’t be held responsible if you do forget people sorry just gotta cover my ass
