Where to find reasonably cheap reliable M92T36 chips?
Fed up with fake M92T36 chips on AliExpress. Bought a few of them from different sellers/store, none was working.
Would you recommend a trustworthy one on Ali or else?
I haven’t had such bad experiences with these chips. HONGYOU is one for example I used often - also you should double check if might the soldering could be the issue instead of the chips?
Maybe my soldering is faulty, but every chip coming from donor board (so genuine I assume) were always working. I try to tin the pads of the chip every time before to ensure a good adhesion to the board.
I didn’t find any m92t on the seller store you mention, only BQ.
Thanks for contributing anyway.
