Xbox Ally X - lifted power key ☹️
How screwed am I? I transferred an Xbox Ally X MB into an Xbox Ally case, and vice-versa, because I like the white case better. Gave the black Xbox Ally to my nephew. Transfer on both went perfectly, but then I decided that I wanted to uses the dpad from my Elite 2 - so ordered the part from etsy and took it apart again. While doing so, I somehow got up under the power key connector instead of the cable and it came off the motherboard with just a tiny bit of pressure applied to it. Is this fixable? I think it’s beyond my capability to fix - so not sure what to do. I can solder, but I can’t microsolder - don’t have the tools or skills and don’t want to make it worse. Thanks for looking!
It seems I can’t include pictures or links, so I don’t know how I can show you the pictures of it :confused:
Saw another poster say to add a to the link, so here it is:
http
_s://reticentrobot.com/wp-content/uploads/2026/04/power-key-close-up-1.png
http_s://reticentrobot.com/wp-content/uploads/2026/04/power-key-close-up-2.png
Torn and almost broken pads on the connector, you likely need some microsoldering tech to repair this if the connector is luckly enough can be reuse
The connector looks very similar to the HRS partbut cant be confirm even from asus schematic has no proper part number label
Yeah it’s pretty screwed. I contacted shanefix, I’m hoping they’ll take this on.
I think this may be the connector but I’m not sure: h_ttps://www.a-accessories.com/rog-ally-accessories/ally-spare-parts/asus-cable-attachment-system-92127-85206.htm#xbox-ally-x-console|l
