Xbox one HDMI fajtuejfjqjfbe
so I am going to try my best to explain this problem I am having.
I send my Xbox in for repairs because it had not picture so the repair place replaced the HDMI and new thermal paste he tested it send me a video of it working and everything looked fine.
got home with the Xbox got it all set up and turned it on but no picture changed the HDMI cable still did not work plugged it in to a different TV still did not work.
took it to a different TV which is a very old TV but has HDMI ports plugged it in turned it on and there was picture worked perfectly.
I change the setting to detect HDMI only took it back to my TVs and home plugged it in turned it on and nothing no picture again.
the only time I get picture is when I plug my Xbox HDMI in to my two into
one HDMI splitter with either my TV box or PlayStation plugged in and on at the same time, is the only time I get picture from my Xbox
at the same time this all was happening Microsoft send out an update package so I am not sure if that update has anything to do with the problem I am have.
Please no double posts.
Did you check for hdcp settings?
Did you check the resolution on your old TV? Is it 1024p or maybe only 720p?
sorry man, just really need the help,
what HDCP settings or did you me hdmi,
the old TV First showed picture at 655 by … can’t remember the I could changed it to 1080p or 720p
and 720p work changed over with out a problem
HDCP is a digital content protection handshake between devices over HDMI. And can lead to blackscreen due to miscommunication between device and tv. A capture card will display a blackscreen if the HDCP handshake is not turned off.
If you get a picture at 720p and not at 1080p at a 1080p tv my best guess is the HDMI ic is bad.
thanks I will have a look it to that.
