Xbox One S Light of Death
Hey there,
I am having a problem with my Xbox One S. I’ve bought it as defective, it wouldn’t power on. I found a short between +12V and GND, identificated a faulty MOSFET and replaced it. Now the short is gone but the console will shut itself down after a few seconds when I power it on. Is there the possibility that the faulty MOSFET has damaged something else and if yes, where could I find the problem?
Thanks in advance,
Michael
Try changing HDD maybe that’s the reason
I don’t think that’s the problem. With the drive removed, it behaves exactly the same.
Check to see if there is anything in line with the mosfett, a voltage regulator or a tranny maybe? There is a pcb I repair at work that if the mosfett gets taken out it kills a couple more components down the line and sometimes the damage is random. Is the new one measuring correctly?
