System came in, all drive games load except COD MW. Replaced drive with GOOD (actually tested). Installed game, same issue. Anyone else have experienced this or found the solution? I do not thing this if hardware related. Side note, cant change home xbox as it says it been done too many times. Claims they own a disc with same result? Also state they get it to load on another xbox. We have a case of screwy board (i find highly unlikely) or some account fuckery by you good friends @ Microsoft?
have you tried putting it back and booting the game again?
Jumped the gun… sorry. Come back the next morning, same failure again…
change drive, change account, reinstall = no change. reformat + OSU1 + differnet game tag + disc install = no changes. Replaced paste = no change. Used power source and different sata to connect the HDD = no change.
I give up… Only got to boot when removing wireless card but next morning same issue. Reading many issues regarding Xbox one X and this game. For the most part I am seeing issues likely related to dirty fan or faulty HDD. Anything I do it goes to COD splash screen then back to dashboard. 1) Maybe it needs SSD? 2) Power supply could be weak? From what I have also seen there was a claim activation says transfer game to external SSD. Hmmm, I wish I had a big enough SSD to try this!!! Good luck all. If your fan is loud = clean it. If it loads and crashes = test your HDD. If your in my situation best of luck, please fill us in if you solve it.
have you tried updating the game before running it?
