My house was struck by lightning last week. Insurance has covered the majority of things including my Xbox and projector. Everything turns on but no picture shows. My projector has 2 HDMI ports, standard and 4k. If I plug a device into the standard port which never has anything connected to it previously works fine. The 4k doesn’t recognize anything. As for the Xbox Series X it seems to turn on but doesn’t display anything when connected to known working tvs or monitors. I can use the controller to turn it on and to turn it off holding the home button, up, and then A like I would when it worked. To me that says the Xbox works but the HDMI is bad. My question is is it worth it to try to get these repaired or is the problem likely bigger and I should just replace?
Thanks in advance.
